A4 first start success...but water leaking from bronze pieces - SailNet Community
post #1 of 10 Old 05-29-2013 Thread Starter
I just finished my A4 rebuild and finally got it started this past weekend. I noticed that after the motor came to temp, that water began to seep out of the round bronze pieces on the top of the head and front of the block...any idea why this is happening? Is it detrimental? How do I stop it?
A4 first start success...but water leaking from bronze pieces-engine-pic.jpg
Thanks guys,
Chris
simmonct is offline
post #2 of 10 Old 05-30-2013
Re: A4 first start success...but water leaking from bronze pieces
If you've rebuilt the engine you must be familiar with Moyer Marine.. I'd give them a call.
Are those frost plugs???
Faster is online now
post #3 of 10 Old 05-30-2013
tommays's Avatar
yes the plug will have to be removed, you can drill a hole in the center and pop it out with a screwdriver
and then clean up the hole as best as possible and hopefully a new plug will seal without needing to resort to goop
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #4 of 10 Old 05-30-2013
One of None
deniseO30's Avatar
My dad would dump black pepper in the coolant.. he came from the depression era though.. funny thing, it does work doesn't smell too bad either.
My last project!
deniseO30 is offline
post #5 of 10 Old 05-30-2013 Thread Starter
Black pepper...that's interesting...how will this help stop the leaking plugs? Will it fill in the small voids? Is there any risk of damaging the motor?
I am trying to avoid having to drill and replace the plugs if possible...just means even MORE delay in hitting the water this season.
Thanks for all the input!
Chris
simmonct is offline
post #6 of 10 Old 05-30-2013
tommays's Avatar
It is a cheep part and a fast repair
The black pepper is a get home Band-Aid as that leak is only going to get bigger as the leak rusts up the hole even worse
Tommays
Northport NY
tommays is offline
post #7 of 10 Old 05-30-2013
One of None
deniseO30's Avatar
Chris were the freeze plugs removed for the rebuild? If it's leaking imho it's already rusty and needs replacement seems to me most freeze plugs are put in reverse to what yours is showing.
Tommays is there an expansion type plug that he could get?
My last project!
post #8 of 10 Old 05-30-2013
tommays's Avatar
It is just a curved disk not like the cups with more sealing area on the sides like newer stuff
You clean things up and see how it looks and the new one could be thumped flat with a socket and plastic hammer
If there is obvious corrosion and it will not seal then it would become goop time like blue RTV
Tommays
Northport NY
tommays is offline
post #9 of 10 Old 05-30-2013
One of None
deniseO30's Avatar
Moyer Marine Online Store
My last project!
post #10 of 10 Old 05-31-2013
MARC2012's Avatar
They used to make some rubber ones .marc
MARC2012 is offline
Leaking Water Tanks RainDog Pacific Seacraft 5 09-30-2009 10:36 AM
Leaking water pump. L124C Diesel 19 08-08-2009 12:00 PM
Leaking water tank plovering Jeanneau 8 07-01-2009 09:53 AM
leaking water tank?? bderosa Gear & Maintenance 5 06-06-2006 10:50 AM
leaking water tank enadler Gear & Maintenance 8 05-25-2006 06:31 PM
