Best way to repair these instrument holes
6.5K views 10 replies 7 participants last post by  PhilCarlson
#1 ·
Hi
The previous owner of my boat had removed the electronics and had covered the holes with two plastic boards with some kind of silicone/putty in the holes. The board was half stuck, half screwed on. It was leaking and just generally looked crappy so I'm working on replacing it.
136975
136976
136977
Here are the holes now i've started to clear them out:
136978
So i'm looking for the best way to re-do this job. I'm not that fussy about aesthetics, as long as it looks better than it did in photos 1 and 2 - looking for a quick, watertight solution.
I guess my options are patching it with fibreglass or re-doing the board solution that was in place? Some Q's:
1.) Could i get a good water tight solution using a board either side and some sealant? While i would one day like to re-do the fibreglass to make it look better, i'm new to this kind of thing and winter is coming... so for a quick fix to see me through the next 6 months i'm wondering if i just replace the boards?
If people would really recommend doing it "right" with fibreglass, some more Qs:
1.) Do i treat each hole as a new fibreglassing project? I.e treat them all in isolation as if the other holes weren't there
2.) what's the best stuff to dissolve this adhesive off the outside of the boat?
136980
3.) Do i need to get all of this rubbery stuff out of the holes before re-doing any work?
136981
Thanks for any advice!
#2 ·
It looks like the previous owner bought a couple of cutting boards from Walmart and slapped them over the holes!
How you deal with them depends on what your future plans are, and what your budget is. Do you plan to mount new instruments there in future?
Obviously the best solution would be to glass them over and redo the gelcoat, but that would take significant fiberglass skills, and even then, matching the gelcoat would be near impossible.
The easiest solution would be to do something similar to what the previous owner did, but choose better materials to do it! If you cover the area with a plastic or wood plate it also gives you the option to mount new instruments where you want at the same time as concealing all the old holes.
I did something similar on my old boat, and you will find another active thread on the subject on this forum that discusses materials a sealants to use.
Sent from my SM-G960W using Tapatalk
#3 · (Edited)
I would recommend using StarBoard plastic material and seal it with 3M 4000 which is water proof and withstands UV. StarBoard is available thur many suppliers but the best price and service is from Mcmaster carr supply. look up Marine grade polyethylene which comes in white or black and some colors McMaster-Carr like pt# 9785T809 about $20 for a 24" by 24" sheet. stole the pic from another recent thread to show how it can look when done right with the right marine materials in lew of the cutting boards that you have now.
136982
#4 ·
I would recommend using StarBoard plastic material and seal it with 3M 4000 which is water proof and withstands UV. StarBoard is available thur many suppliers but the best price and service is from Mcmaster carr supply. look up Marine grade polyethylene which comes in white or black and some colors McMaster-Carr like pt# 9785T809 about $20 for a 24" by 24" sheet. stole the pic from another recent thread to show how it can look when done right with the right marine materials in lew of the cutting boards that you have now. View attachment 136982
That looks like the same material I used, so my pic above gives an idea how it will weather over the years.
You can see in one of the OPs pic what UV does to cutting board material. It goes translucent and brittle with little cracks throughout.
#5 ·
I was also going to suggest teak as an alternative to Starboard, but I think those holes may be too big. I had one four inch hole like that, and I covered it with two teak switch plates that I stacked together. The plates were "blank" so you could cut your own holes in them for use as a switch or plug. I used it as a base to mount my new chartplotter. I sealed the plates with 4200. I thought it looked pretty boss, especially when the teak was new. Unfortunately, the unit kept getting kicked when anyone would move forward, so it had to go. That left the plates just sitting there for a couple of years. I had plans to replace the plates with a piece of Starboard, but I never got around to it. This is a picture of the area taken after I had unmounted the chart plotter and moved it to a foldaway arm. Note the classy white tape on one of the plates. It's covering the hole I drilled there to run the power/transducer cables. Note too the screw holes for two other projects that didn't last too long: The screw holes didn't go through the bulkhead, so I never bothered to fill them.
#9 ·
If I understand correctly you will also have to deal with the holes from inside the cabin. If so you can mount a new thin piece of starboard with 4200 and use a temporary piece of wood about 1" wide on the inside with a "clearance hole" Place the screw into 'thru" the clearance hold and then the back side of the new starboard with the adhesive. As you tight the screw it will pull the starboard tight to the fiberglass. adhesive will ooze out and that needs to be cleaned. Let the 4200 set and remove the temporary "clamping" wood strip. Now you can attach whatever material you want to cover the holes on the inside. You can use 4200 to adhere it... could be starboard, or teak... or any species of wood you like. Hold it in place with tape and remove the tape when the adhesive sets. You can also mount something inside like a box to hold something... a clock whatever.
#11 ·
I'd go with glassing them in. It's really not that difficult and a good project to learn on if you haven't done any fiberglass work. It may be a bit more involved, but ultimately will look nicer and won't ever leak. Youtube is your friend if you go this route.
Alternatively, I would fabricate a cap out of starboard similar to the one that is there, and a backing plate of the same dimentions. You're going to need to thru-bolt it every few inches to maintain a good seal. I'd use butyl tape as the sealent vs a sealent/adhesive. The starboard plate and the fiberglass it's attached to will experience different thermal expansion so you can expect a need to replace that gasket down the line. Butyl will be much easier to remove and replace.
