In making windows in enclosures and dodgers and the like thin plastic sheets like acrylic/polycarbonate seem to offer superior viability over things like stratoglass (with the only negative that they can't be rolled). Based on my research acrylic is also inherently UV resistant, while polycarbonate (such as makrolon, which can be sewn in) will yellow especially in high UV areas. EZ2CY, on the other hand, does not seem to degrade like polycarbonate. EZ2CY seems to just be acrylic plexiglass, but I could not find much information on how one could install this themselves, as it is bonded instead of sewn in. So I read through this very lengthy and wordy patent and condensed it down to some simple steps. Hopefully this will be helpful to someone as I could not find this information anywhere else.
This will supposedly work for bonding sunbrella and various other fabrics 5-15oz in weight or vinyl like stamoid to ABS, acrylic, polycarbonate, nylon, polyethylene, polypropylene, polystyrene and vinyl based sheets. For more information here is the patent in question:
https://patents.google.com/patent/WO1995018189A1/en
1.) plastic sheet (at least 1/16" thick)
-cut to size with 1 inch extra on all edges
-edges are sanded down on both sides, removing 1/32" total thickness from the edge to 1 inch inwards
-smooth edge (patent mentions using bullnose router bit)
2.) 2 layers of sunbrella with acrylic in between
-coat sunbrella edges that will be bonded to plastic 1" wide in epoxy resin (3M dp100) (1/64-1/32" thick)
-let cure (6-8 hr usually)
3.) bond plastic sheet to sunbrella with double sided foam tape 3M VHB 4949 (both sides)
-apply slight pressure (like with a roller)
4.) sew two sunbrella layers together with two seams, one near edge of plastic and one near sunbrella edge
So it seems like you would bond the plastic sheet to the main piece, and make a strip for the other sides to cover the edges also bonded to the plastic sheet. You could also probably sew some vinyl to the sunbrella and attach the plastic sheet to the vinyl instead as follows.
For vinyl like stamoid, no resin is needed
-abraid plastic sheet edges
-wash acrylic edge with acetone
-use tape 3M vhb 4945, ps 4425, ps 4430, or ps 4445 to bond
Hopefully this made sense, but you can also read page 16 of the patent (pdf version) titled "Examples" which might make it more clear.
