I'm a new owner of a 1978 Catalina 27. The boat didn't cost enough to warrant a survey, so I've spent the past two weeks getting into every nook and cranny to start putting a list together of all of the maintenance required to make her a reliable and seaworthy vessel. The Jabsco toilet doesn't take any water in from the thru-hull. The knob on the seacock spins and spins without opening. The seacock for the sink and icebox drain tube performs the same. Would anyone care to impart some wisdom on how I should go about replacing the valves? Will I have to haul the boat out in order to swap out hardware? Photo 1 goes to the Jabsco, photo 2 goes to sink and icebox drain hoses.
Thanks,
Brandon
Thanks,
Brandon
