I was thinking the same thing about the loop. I was unclear in my description - the cockpit drains to the large bilge area below, which is separated from the cabin by a plywood bulkhead. This has a drainage hole at its base, so it drains into the bulkhead beneath the companionway step/sink. This area has the non functioning bilge pump, whose hose routes to the cockpit outlet near the stern. It also has a hole at its base, which allows water to drain to the cabin sole if the pump doesn’t work. This seems like a poor layout and has led to soggy bulkheads when rainwater collects in the cockpit and inevitably drains below. When installing a new bilge pump I wonder if I should locate it in the main bulge area and close up the drain holes, or keep it beneath the companionway. It is more accessible there, but necessitates the connection between bilge and cabin. In any case, I am thinking that moving the bilge pump outlet to the outboard well would make more sense. This is the companionway bulkhead with the old bilge pump:
Great idea about searching for other DS20s for reference photos. I was able to find two, one with a compression post and one without!
I took some closer pics of the area beneath the mast step. I can’t see any evidence of a post having been there, other than what could be a single bolt hole through the reinforced gusset area, which is about 6 inches forwards of the mast plate bolts. The circle and other small screw holes are from the old lights I removed, which were directly below the mast.
The boat was sailed this way by the previous owner. Even if it the original design doesn’t use the compression post, I wonder if adding one, or a nice arch like AllThumbs, would be a worthwhile addition.
Today I have stripped out the interior for a coat of paint and sanded down the tiller handle for a new finish. Thanks!
