Looking for a new 135% genoa for my catalina 38. The current one from PO is a 150% that was recut by them and now doesn't really fit the boat (or never did) and the sailmaker estimated was about 12 years old, on it's second UV cover. In the aftmost track positions (which are only about 1ft away from the winches so can't extend those without also moving winches), the fairlead is pulling straight down on the leech so.. can never get good sail shape up wind as it bags out in the front and the leech curls.
My use case:
Since i'm not circumnavigating or anything, would like to lean on performance, getting better at sail trim.. etc. And I'd like it to last, so so far looking at tri-radial
Tailing with local Sailmaker.. Covid has materials all over the place and upside down cost. His first 3 proposals were, in order of price LOWEST to most expensive. Based on availability also given supply chain problems.
So, given the sailing hours and intended use, opinions? What's going to grow with me and not die of UV damage or abuse before I even can appreciate it? While maybe not overpaying for stuff that isn't going to matter.. i guess. the "good enough" sweet spot.
My use case:
- First boat - there are days where the sail might flog a bit either during a tack or trying to furl it. we know this is bad, we will get better.. but we are not there now so don't want to buy a sail we destroy right off the bat (takes some abuse is a characteristic we want)
- On a furler
- Day sailing around San Diego, light wind area (10 knot average - good days are 16 knots)
- Probably 250 sailing hours a year until retirement in 10 years
- Dimension CDI cruising laminate (on clearance basically cause they have moved to CDX)
- Challenge Ultra Palma - ultra-PE reinforced cruising laminate - so new they don't even have anything on their website yet / nobody has a sail made from this.
- Contender Pro Radial - woven ; yes this is the most expensive - covid/demand?
- Contender Pro Hybrid w/ Dyneema - i asked for this one based on searching here / google and people like it and Hyrdranet, this one being the cheaper of those two
