How many ***FEET*** of anchor chain do you carry aboard?
  • < 50
    Votes: 7 20%
  • 50-99
    Votes: 6 17%
  • 100 - 149
    Votes: 8 23%
  • 150 - 199
    Votes: 3 8.6%
  • 200 - 249
    Votes: 5 14%
  • 250 - 299
    Votes: 3 8.6%
  • > 300
    Votes: 3 8.6%
How much chain do you have?
9K views 30 replies 17 participants last post by  JMEJ
#1 ·
While stuck here in St. Lucia at the dock I'm doing a number of boat projects that I've been postponing, and a couple of days ago I decided to take my chain out completely and clean the rust off it and turn it end-for-end again. I haven't used more than 100 feet since the boat was recommissioned after getting damaged in hurricane Irma and even before that I'd had some bad rust. I got special G70 chain, but sourced it badly and didn't get the quality I wanted, so as soon as the galvanization was abraded by the bottom sand it started to rust. Most of the chain is good, but there are links and small sections which were at the bottom of the chain locker and got very corroded. And there was a solid rust ball at the end of the chain that even 24 hours of soaking in hydrochloric acid didn't quite loosen!
My original plan was to head to the Pacific and deep anchorages, so I originally got a lot of chain (over 150m - almost 500'). But now I think I'll probably be in the Caribbean for the life of my replacement chain, so I've been thinking about minimizing cost (and weight) for a full-chain replacement.
I can get a full drum of chain (10mm / 3/8") of 360' which is what I'm thinking of getting, I've anchored in 50-60' many times and used 300 feet or so. But usually I'm in much shallower water.
#2 · (Edited)
I have 200'. Couple of months ago I had 300+. 2 years ago I reversed the chain and the old 100' that was used most became a rusted ball in bottom of lock that became a scarily thing to remove.
#4 ·
I carry ~250' of 3/8" chain on the main rode. I have a secondary rode with 80' of 3/8" (and then another 200' of nylon). I can join these if need be, but there's never yet been a need to be.
Typically, we lay to about 100 to 150 feet of chain (not including snubber length). Most of our anchorages are 20 to 30 feet, although sometimes we manage to get into less than 10' at low tide -- that's always interesting given our 6' draft 😬.
#5 ·
Operating from North Carolina north into the Chesapeake Bay and south into the Bahamas, we have three anchors.
The primary on the bow - 45lb Rocna, 137' 5/16" BBB chain, 170' 5/8" nylon (137 ft is 1/4 of a barrel; I bought at a great price. The nylon seldom gets wet.)
The secondary on the bow - 44lb Bruce, 50' 5/16" BBB chain, 182' 5/8" nylon (Seldom used.)
On the stern - FX16 Fortress, 25' 5/16" BBB chain, 250' 1/2" nylon (Used as a stern anchor and for extracting us from our mistakes.)
#8 ·
We have 100m(328ft) of 1/2” chain. Just yesterday, I was anchored in over 50ft of water. Slept like a baby. Currently in 20ft, but I expect tonight’s anchorage to be in the 30-35ft range. I also have a 55kg(121lb) Rocna anchor. I’ve wanted this set up for years! It’s like dropping my own mooring. 🙂
The best part about having deep water capability is finding a spot few others want to crowd into.
I sourced my chain from Defender, in the States. ACCO brand. I’m happy with it so far.
If you have ample fresh water, a rinse of the anchor locker goes a long way. You can eat up 10 gallons doing it.
#12 ·
I have 75 meters / 250 feet chain. And I use it ALL!!
I had out 65 meters in 5 meters water depth the other night in 50 knots. I would have laid out the rest but was coming too close to another boat.
There is no value having chain in the locker in a storm!!
For the rusting, I put in the bottom of the anchor locker in plastic tiles - see photo edited in. This keeps the chain off the wet floor. Note I have a little puddle permanently in the bottom of the locker.
140423
#14 ·
Mark - in flying we used to say that runway behind you and altitude above you are useless - just like anchor chain in the locker :cool: Can you user your mod powers for good and modify the poll numbers so that they don't overlap? I am going to have put something like what you have in my locker to keep my new chain from getting infected with rust
#20 ·
My container with 360 feet of G4 chain is arriving on island tomorrow and I just got paid so can afford the bill to pay for it as well. I am going to splice another 100 feet of rode to the end of the chain so I think I'm ready for pretty much any anchorage regardless of bottom. I still need to figure out a system to keep the chain an inch off the bottom of my locker to allow for drainage. While Mark's system will work and I have the exact same mats aboard (commercial kitchen drainage mats from a restaurant supply store in St. Martin) I think I might construct something with starboard.
My neighbor at the dock has spray cans with red, green and blue paint so now I have to figure out a marking system. That might be worth a whole other thread...
#24 ·
I just did my 2nd run with FSR to remove rust in the chain locker. I climb in and can almost stand upright in it and the depth is about 5 feet with a pointy end forward and about a 4 foot width at the widest end. I had 450 feet of chain originally and that didn't even fill a quarter of the locker volume. The 2 drainage holes are similar to what Mark posted earlier in this thread and the water pools at the forward section, not the aft section. Perhaps I only need a bit of "height" forward to keep the chain out of standing water. I've got some Starboard that I've never used and it is close to its expiry date (I give away or discard everything older than 3 years that I haven't used) that could do the trick.
@SanderO - I've got 10 San Pelligrino bottles filled with tapwater in my freezer right now... They might be better in my chain locker :)
#27 ·
The "floor" or the anchor locker should be sloped (forward) with a hole of no less than 20mm which prevents standing water from accumulating, This can be accomplished with a solid starboard shelf. The drain hole on my Contest can be seen here below. It is at the bottom of the anchor locker and as you can see maybe 15-18" above the water line. The location is very hard to get to from the inside. The bottom is narrow and solid fiberglas.
#28 ·
I've always felt that right around 100' is a sweet spot for cruisers trying to save weight but liking chain. They can anchor with no chain on the bottom at reasonably long scope in water up to about 12-15 feet (depending on the length of the snubber). Deeper than that they still won't have rope on the bottom if there is any wind. As for catenary, the first 100 feet do most of the work (better leverage on the rode).
But no one best answer.
#29 ·
I have a few boats that are used for different things. They have different amounts of chain. My little 17' fishing boat has 10' of chain & 200' of line. My little Hunter 265 has 10' of chain on one anchor & 30' on the other. My Aloha 32 currently has 30' on each of two anchors, and 50' on another. The 50 will be getting upgraded to 100 or 200 before I take her on an extended trip to the other side of the gulf stream. The most rode I have put out on that boat recently is 275' to anchor for a short time while diving in 70' of water. I didn't vote above, since I would need to enter multiple answers to be accurate.
#31 ·
Primary anchor (Plastimo Kobra II) has forty feet of chain with 200' of nylon line. Secondary anchor (Fortress) has fifteen feet of chain and about 175' of nylon. Never wished I had more (and haven't dragged) in eight years of cruising back and forth between Maine and Grenada.
I am knocking wood furiously....
Chain is heavy and expensive, and it rusts. There used to be a good discussion online by an Australian guy, I think, about how having a bunch of chain out really doesn't create any catenary in winds over about 40 knots (when you need it.) But having all chain does, in that instance, rob you of elasticity (which you arguably do need.)
So I chose to go with one boat length of chain and the rest nylon, and so far, at least, it's worked pretty well. When the wind is howling, I try not to spend a lot of time thinking about that nylon rode, except to let out a few feet every now and then so it will chafe in a different spot.
