MYSTERY CARBON MONOXIDE ON BOAT!
11K views 106 replies 24 participants last post by  OntarioTheLake
#1 · (Edited)
Good Morning All,
We just bought a little Tayana 37 and I just bought the Co2 and smoke alarms yesterday- 2- One in the rear of the salon area across from the galley, and the other up forward in the V berth. Neither are mounted yet, but I put both around chest to head height.
Last night we cooked dinner, ate dinner, sat around for a few minutes and then the alarm in the galley area started going off with a Co2 level of over 90ppm. I put the dog on deck, opened up the boat and sat in the companionway for a few minutes when the one in the V berth started going off. With that said, I think it's safe to say the Co2 came from aft and moved forward, likely the oven or stove that had been used earlier.
Here's the thing that gets confusing though- a few hours after we went to bed, the one in the V berth went off. Could that from my fiancé farting?!
We have a diesel engine, diesel heater that isn't running, we have a new electric hot water heater, all new components on the propane tank that is on deck currently in the cockpit, so my next assumption is that this was just a build up from cooking, and 90ppm isn't really "that bad", thought the internet has a VERY wide opinion of which number ppm one should be alarmed at. I also assume we shouldn't keep one in the V berth if my fiancé is going to fart all night?
So my question is this- These particular detectors go off at around 30-40ppm (maybe the Kidde ones from West Marine go off at a higher level?), and I'd think it'll probably do that nearly every time we cook or use the oven, and every time the Mister is aboard. These things are loud enough to wake up the whole marina. Where in the world could it be coming from? And if it IS the oven, why has this never happened before on any other boat I've ever lived or worked on over multiple decades?
#2 ·
Something sounds strange and its more than farting. I don't think I have ever had a CO detector go off even with the deisel inboard running hard.
Exhaust from a neighbouring boat getting sucked down your vents or an open port?
#3 ·
Do you have a CO or CO2 detector? Combusting propane produces CO2. Doing so with insufficient oxygen produces CO. I doubt that an enclosed boat would be oxygen starved, but I suppose it’s possible over time.
First you need to know the difference between CO and CO2 to figure it out. Since CO2 detectors are specialty devices, I suspect you mean CO. These use IR to detect so it’s possible other airborne elements are causing it to false.
#4 ·
Sorry, correct. It is a carbon monoxide detector, or CO detector only. But they're something that everyone keeps on their boat, so I'm not sure I understand how everyone doesn't encounter this issue. And I've worked on countless boats, and we never had issues with the alarms going off, so it's something on this boat.
#11 ·
Overly-sensitive or dysfunctional detector? I would get a hold of another detector from another boat -- one that isn't known to go off all the time. And, take yours onto another boat which doesn't set of their alarms.
CO is typically a product of incomplete combustion, so if it happens after, or during, running the main engine, or after cooking, you have the beginning of an answer.
There is not typically much CO in fart gas, so it's very unlikely to be that.
#14 ·
These are new detectors and there are two. One went off minutes after the other, so I don't believe them to be faulty. Also, they read the CO level on the display, so I can watch it go up and down and track the area it's in. It moved from aft to forward, so I still suspect it's to do with the stove, I just don't know exactly what's happening and why it would be going off in the night hours after using it.
#21 ·
They are sensitive to hydrogen.
Was this the FIRST time you used the stove or the oven?
Had you just cleaned the stove or oven?
Where are you? Are you heating the boat and if so how?
Not the first time using the oven, but first day with smoke/Co detectors on the boat. We've had this boat for a week and there were none on the boat.
Hadn't cleaned the oven, no. We had just used it, but detectors didn't go off until maybe 30 minutes after turning the oven off. Opened the whole boat up until the levels dropped throughout (these detectors have a numerical display for the ppm so I can watch it drop, and see where it's at a higher and lower concentration), but then again in the night the one in the V berth went off again (the batteries were out of the second one in the salon at that point because we thought we were in the clear).
My assumption, based on the first event, is that it's coming from back aft somewhere- probably the oven, maybe the batteries. The batteries ARE a few years old, but the area they're in is packed with stuff. These batteries have the special caps on them to prevent an explosion, should they not have proper airflow, but there is "some" ventilation.
We have a 16,000 btu marine air conditioner that we use daily right now, and we're in Florida, so it stays around 76-80 degrees F in the boat. It runs non-stop, usually. There is a diesel heater also in the boat and we did use it maybe 4-5 days ago, but haven't used it since.
#23 ·
If the batteries were on charge at the times this happened (or you are on shore power), I think looking at the batteries makes sense. As someone else said, cheapish CO detectors are very cross sensitive to H2, sometimes up to 2.5x. so a reading of 40 ppm CO might be just 15 ppm H2.
I know you said you have lots of stuff piled up around the batteries but H2 is not easily contained (definitely not by couch cushions). Maybe put an alarm in that cabin and see if it alarms in there too?
~f
#26 ·
We have issues with our co detectors if the boat has been closed and humidity gets to high. We also have issues occasionally when the exhaust from boats nearby finds it's way in through open hatches. Never had an issue with the stove or lead acid batteries
#31 ·
Both times was pretty late at night, so not boats coming in and out. Surely it wouldn't be humidity... the AC runs ALL DAY (not by my choice hahah) so humidity levels aren't extremely high or anything, through it is Florida.
#27 ·
I appreciate your answering all our silly questions.
I have had a CO alarm go off due to outside sources. Once it was my diesel heater, we were at dock and there was a very slight wafting wind. It was enough to bring some gas ito te cabin.
I forget other circumstances.
You best option may be to monitor the alarms for some days, annoying as that may be. It is possible this was a one off weird occurrence. But if repetitive you may eventually see some pattern to it.
I would NOT ignore it.
I would consider purchasing a third detector, either similar or from a different store. Try to make sure the quality stamp shows a different lot. Mike ORiley's suspicion of a identical bad problems has merit. I had RayMarine send me a tiller pilot with a bad gyro. Then the replacement also had a bad gyro. EXACT SAME PROBLEM.
Not unheard of.
#30 ·
Not unheard of.
Ok, I'm going to get a Kidde, since they're known and reputable. Maybe that will help decipher what's going on next time it happens.
We do have a diesel heater but hadn't used it in a few days.
The alarms have gone off again in a couple of days! We use the stove daily, but haven't baked since that night. I guess if we bake something tonight we might know.
#42 ·
I love hearing that you purchased CO (with digital display) along with smoke alarms and posted this question. I’m thrilled so many boaters expanded on possible causes (i.e., acid battery off-gassing, exhaust leaks, propane locker leak, etc.). I had heard about a couple that initially thought the headaches and nausea they experience was from seasickness until they discovered that propane was leaking from the propane locker into their aft cabin where the propane pipe ran through.
To answer your questions on whether 90 PPM is dangerous, the “Fire Series: #1 Detection article“ has a CO PPM table and explains "continuous or intermittent exposure to carbon monoxide through your lungs and into in your bloodstream is cumulative over hours or even days. So even if you go out on deck or out for lunch for an hour or two, the carbon monoxide you inhaled is still in your blood. It takes four to six hours in fresh air to exhale about half of the inhaled carbon monoxide in the blood, starting from the last time of exposure."
So please continue to take the CO detection as seriously as you have and consider purchasing or borrow 1-2 more CO detectors with digital PPM displays to see if the additional CO detectors get the same reading or if the initial CO is faulty. I have lent my CO detectors to fellow boaters who have experienced the same issue many times.
We sail almost year-round on our 39’ sailboat, so we literally have 2 CO detectors in every cabin.
#45 ·
Thank you! It went off again last night, both of them in the middle of the night, we hadn’t cooked, there were no boats moving around outside… AND we left town today and the marina just called and said they were going off right now and someone just called the marina.
we bought these off Amazon, and I trust the Kidde brand but I can’t find a good one with the display. Is there a brand you recommend that has the display?
#43 ·
To add, while leaking propane will not be detected by a CO monitor, they do make raw propane detectors too. Really smart idea to have them positioned where a leak might go. Propane is heavier than air, so a hose leaks by gravity. CO rises, a bit. Wafts is probably more appropriate.
#44 ·
Good morning, Consider purchasing a hand held CO detector that are available from Amazon for less than $40. Not lab quality but you'll find the problem in a few minutes. I suspect incomplete combusion on the oven.
Good luck and be careful, this is a bid deal.
#47 ·
Is that still possible even when we haven’t been using the oven?
#59 ·
The two posts you quote with this reply were referring to different things. Mine to raw propane leaks (explosive risk), the other to CO. It is possible to get a propane leak, when you're not using the stove, if you fail to shut the tank off in its locker. I always found it to be the safest practice to shut the gas off, while the burner was ignited to reduce the pressure in the hose. Even with the tank closed, the gas in the hose could theoretically leak, but I do not think it's all that much.
Before I overstate the explosive risk, from raw propane, it's extremely uncommon. Your boat sound like it's had some deferred maintenance, with prior owners, so maybe a higher risk.
#49 ·
Have you tried to take a measure inside the battery box?
If it's not incomplete combustion, and it's not from the outside, and it's not a faulty detector (I'm still not convinced it's not), then what is left? Seems to me it has to be H2 production from the batteries. It's also possible to have H2 production from arcing electricity, so a bare short somewhere, but that wouldn't produce much.
#50 ·
It does always start “near” the batteries, because the batteries are under the pilot berth and the alarm is at the nav station just forward of that. Today I’m going to move one into the pilot cabin and then keep the one at the nav across from the galley and then see which one goes off first. That will tell us a lot!
I ordered another one that will arrive tomorrow and it’s a Kidde with a display.
#53 ·
Buckle up.
Sometimes these things work out and sometimes not.
MybWife and I are an odd couple, se would never have left the dock, ever. Yet here we are as live aboard in Caribbean in season.
People are odd as can be, and there is no telling what works and what does not between us.
Goeed lunch however it goes.
#56 ·
There’s no generator and it happens when we haven’t been running the engine. We did run the engine yesterday in the morning but those alarms didn’t go off until the middle of the night last night. The other times, I don’t think we’d ran the engine.
