Ive got on order a new Nissan 9.8 four stroke.
This outboard looks like it has the same sort of magneto - rectifier setup my current 1990 Honda BF8 outboard does. In larger outboards and inboards, the charging system has a regulator which has feedback to the alternator to control how much charge is being put out depending on the battery voltage. This also makes the charging less dependent of RPM. The magneto - rectifier on these smaller outboard has no voltage feedback.
So first question is to confirm the charging system in this Nissan 4sk 9.8 hp outboard has no regulator (looks like it to me from the schematic in the manual).
Second, assuming a magneto - rectifier setup, I have seen an RPM dependent charge output from my old Honda BF8 (I have a linklite charge monitor). Im assuming the new Nissan 9.8 will do the same.
However, I "think" I may have also observed somewhat of a battery voltage dependence on the charging. Ie, as the battery voltage rises, the charge output went down. But Im just not sure and I also have seen my old Honda put out over 20 volts when operated into just a resistive load - ie, this was about the "open circuit" output of the charger.
Im worried about all this because there is one trip I do where I motor a lot (Lake Powell) and Im already generating all the charge I need with 60 watts of solar. Im wondering if I have some chance of over charging the batteries because the outboard has no regulator. On the old Honda without electric start, no problem, just dont connect the charging system for this trip. But the new outboard has electric start which needs the battery to be connected to be started and its dangerous to the rectifier to disconnect the battery after the outboard is running.. Id rather avoid the aftermarket regulators which just put a load on the sytem if the battery voltage gets too high.
I may do more of a controlled experiment on the outboard where I vary the battery voltage at a constant RPM measuring current and also vary the RPM at a constant voltage and measure current- but its a bit of a pain to set this all up so no sure Ill actually get around to doing this...
