This spring our boat will be fifty years old and in our care for only the last forty five of those fifty years..
She is rather well cared for.. New lighter Klacko Mast and boom last spring, updated high aspect ratio rudder then as well. The mast is 150 pounds lighter than the OEM spar the rudder solved drag, handling, balance issues to perfection. The extrusion has a variable wall thickness and it is two inches less in circumference than the OEM mast is.. The combination of both have transformed the performance of what was already a very fast boat to a wicked quick boat.. We retained both the OEM mast and rudder as spares.. Yes there are two masts/booms and two rudders for this boat..
She has an extensive sail inventory 3 mainsails, drifter, light #1, medium #1 (155%), heavy #1, #2, #3, #4, staysail, 1/2, 2 x 3/4, 1.5 ounce symmetrical chutes..
Sail tech Hydraulic backstay adjuster, current Ray Marine instruments (wind, depth, speed, pilot with wireless remote - integrated to a Cobra chart plotter, The pilot can steer magnetic, Apparent wind direction or GPS way point.. dual station Standard Horizon VHV, GPS repeater, AIS receiver, KVH steering compass.. Teak cockpit grating, Bimini, Dodger, 200/300 watts of solar panels, 100 AH LIFEPO4 house battery, 100 AH AGM starting battery, Xantrex inverter / charger, Separate AC and DC panels including sub panels fo reach, central ELCI protection, Smart plug, 17 AC outlets distributed through the boat, LED lighting inside and outside (in dodger, end of boom, at helm, refrigerator, every locker and mechanical space, many additional direct adn indirect LED lights.. CD AM FM stereo, 26 inch flat screen, Mast head wide angle camera (collision avoidance), Dyneema halyards, Dyneema spin after guys, light and heavy spin sheets, Dyneema pole topping lift, automatic latching pole end fitting, whisker pole, reaching strut, Harken main traveller and main sheet, Self tailing secondary winches, self tailing main halyard and Genoa halyard winches, Main halyard run aft, preventers run aft, Cunningham, 10:1 outhaul and main topping lift all run aft, two spin halyards, welded pulpits, refinished hull and deck, new Facnoaur flat deck Genoa furling, She has her original (rebuilt) A4 plus a fully rebuilt spare engine, external Xantrex regulator, Venus engine coupling, folding two bead Michigan wheel prop - and a spare one and a solid two blade Michigan wheel prop.. The engine has a secondary water strainer to catch broken impeller bits, It has high water temperature and low oil pressure alarms, there is an integral oil change pump on this engine.. Custom hardwood cabin sole (level) custom wilton wool carpet set, Jabsco quiet flush electric head, new foam in cushions and new upholstery, Interior has been refinished including interior paint.. Custom varnished cedar in V berth and quarter berth.. Ah the galley.. custom pots and pans drawers, two cutlery drawers, combination microwave/air fry/convection oven, dishwasher, induction cook top, hot water tank, refrigeration, new countertop, manual foot pump for galley in addition to running water.. LED task lighting over counters and in lockers, soap storage under dishwasher.. We fit a new Lewmar Series 60 forward hatch to the boat.. there is an opening port in the head and a doggy door (opening port) in the quarter berth to the cockpit that our Chihuahuas use to get out into the cockpit.. or to head down below from the cockpit.. To keep things comfortable on board there is a 14KBTU heat pump.. (15KBTU heat plus dehumidification setting).. The boat has an air switch for the diaphragm bilge pump.. there is a high water bilge alarm fitted to the boat as well as CO / smoke and explosive fume detectors.. There is an AC power monitoring display and a DC battery monitoring system (link 1000 by Xantrex)... 150 L Vetus water tank.. 40 L holding tank The boat also has hydronic cabin heating off of waste engine heat or stored heat in the hot water heater.. The TV is fed by the wide angle HD mast head camera, the digital TV antenna or an IPTV box the screen is visible from the helm while sailing..
One of the great things about the Viking 33 is there is no core in the hull.. the core in the deck is accessible from inside as there is no inner liner.. So repairs if they are needed is no big deal.. The other crazy thing is that it has a Ballast Displacement ratio that OEM was 53% - 4507 pounds of ballast for 8800 pounds of boat.. and the lighter mast just improved the already great stiffness of the boat rather dramatically.. One of the things many people would NOT like about our boat is the head room or lack there of for taller people.. Its not a problem for OUR family but we are vertically challenged.. If you are taller than about 5'8.. you would NOT be happy on our boat long term..
See what happens when I have a boat for 45 years? It not only is fast.. but it has more blades than any Swiss army knife ever had.. There is not another boat quite like this one.. anywhere..
I like this picture - a lot - it shows the boat developing significant forward PUNCH while standing very vertical and it shows a super clean exit at the transom.. The whole summer I kept looking a the absence of turbulence and loving this new rudder.. all the more.. My Family really appreciates how resistant this boat is to heeling.. I like that I can put up more sail than I used to and still not heel the boat over...
This shot also shows the spectra mainsail rigged
The custom dining table has a mount that allows it to store against the main bulkhead when not in use and to pivot out and telescope aft when needed.. This removes the obstacle and obstruction that a fixed dining table represents.. and it frees up the interior cabin space in dramatic fashion..
So not only does it use less water but I NEVER have to listen to anyone say - who is washing and who is drying... AGAIN.. Truth is this is the great equalizer on the boat.. everyone can relax after dinner and no dirty glasses or dishes ever go into the galley sink.. it keeps things neat and tidy.. Right after a meal - into the dishwasher goes the dishes.... it turned out to be a very practical thing to have on a boat..
So when you step below deck you know exactly what is in front of you...
This is what the camera looks like at the top of the mast..
The change in rudder .. is dramatic in effect, narrower, deeper, better balanced, less wetted surface area.. more control, less drag, less turbulence.. HUGE big deal..
King sized sheets are needed to transit the width of the V Berth The addition of the varnished cedar made this bunk a very cozy place.. You can see the oval custom vent for the heat pump forward to starboard - I could not find one I liked so I built this one..
