Hi,
We are proceeding nicely with our build of our propane locker for 2 - 21/2 gal composite propane tanks. We decide to build the locker because we could not find one that works with two 2 ½ gal composite tanks and the others were real costly. Any way my issue is the only space we have to put the locker in our 1978 36 ft sail boat is in the port lazzerett. It also is a bit low. Not real low but I am trying to work out the drain solution. It of course needs to drain out any leaking propane to the outside of the boat. The idea we have been thinking of is a scupper (to keep weight down) coming out the bottom of the locker and then a hose to a through hole with a valve on it for safety above the water line and at a slight downward slant. We do not want water coming into the propane locker when healing over. This may require a long hose towards the stern aft port side for a through hole. The hose would need to be attached to the hull so gear does not put a low spot in it.
To avoid running a long hose to a aft through hole there is a through hole with a flapper in it. This would enable us to run a short hose to the hull next to the propane locker. This would seem to work if it was pointed down as the flapper would hang open as on the side of the port hull low. Then if healing over it would (the flapper) prevent water from getting into the propane locker. It is not the best solution as we would need to check the flapper from time to time. However it is an option or is it is my question.
What size vent is also a question, hose and through hole.
Anyone have any other ideas or sugestions and what would be the issues witht he flapper through hole, if it stays open?
Example:
Example:
