wing and wing, wing on wing, goose wing ... what do you call it?
5.5K views 42 replies 22 participants last post by  MarkofSeaLife
#1 ·
or something else?
I think I like "goose wing" the best.
#12 ·
As a writer, I look in dictionaries:
Collins: wing and wing. Nautical
with sails extended on either side by booms
Websters: wing and wing. With sails extended on both sides. First use in 1781.
Wiki lists wing on wing and goose wing as alternate expressions.
OED (the definitive source of English, some would say): Wing-and-wing. first use 1810s.
Several sailing magazine style guides: wing and wing.
So it is wing and wing, the only question being whether it is hyphenated, but in American usage, it seems not.
I will sail wing and wing down rivers and narrow channels, when reaching would be a pain, and in a good blow when reaching is rougher than running. Running is yaw-free on multihulls, like being on tracks. A little slower than reaching, but in big waves there is a lot less rolling, practically none.
#15 ·
Wing and wing using foresail and main on a Marconi rigged sloop.
Perhaps goosewing applies to a double headsail rig?
We now have a staysail ketch, so we use a foresail and the mizzen sail [jib and jigger] instead of foresail and main.
I previously owned cutter rigged sloops, and find the ketch is by far easier to manage downwind.
FWIW
Cheers, Bill
#16 ·
Twin headsails are another sensible rig, but not many of us are set up for it. I think this is a proper nomenclature, because if we mean a cutter rig we would say so. Twin means they are the same, not that there are two.
#17 ·
I raced on an Italian boat in an international series where I was the only non-Italian speaker...
It became quickly apparent that the skipper did not use his excellent English in any nautical command. I would sit there while he described the next manoeuvre in Italian and then shout "Go" (or something in Italian) and I had to race up the foredeck pondering what the hell was going on!
There is NOT ONE WORD that is nautically ubiquitous across countries.
When I was on an American boat winning the World Championships their terminology was different for every line, sheet and bit of rope on the foredeck, except halyard.
Try running up the spinnaker or trimming it, when its as if they're all speaking Italian...
Crazy
Mark
#19 ·
Crazy
Mark
It's interesting that sailing language is local to a country... almost. The good think is that I sail alone and so I don't have conversations or commands to deal with. I did know all the jargon and did several courses related to sailing and navigation. Now I simply do what i natural. I am sure things would be different in unfamiliar waters.
#26 ·
Personally I call it "time to put up the spinnaker...."
But I have always believed it to be Wing and Wing.
Interestingly I pulled out a couple sailing books from the 1960's. The first book was the one that I learned to sail with in the early 1960's and it avoided the term entirely, but the 1963 Encyclopedia of Sailing called it Wing and Wing (Glossary of Sailing Terms, pg 466)
H.A. Calahan's 1932 "Learning to Sail" calls it "Wung-Out" and goes on to explain that derives from being "Wing and wing".
So it would appear that the historic term is either wung-out or wing and wing.
#27 ·
From which country were the books? If they are written in the USA they could be different from the UK.
Its certainly an interesting bit of fun... but for new sailors, again, it shows theres too many terms in use and no authoritive glossary.
I did have a link to some old British Admiralty one, but cant find it. :(
#28 ·
Like so many things there will be localisms and local jargon. I don't know that it's a bad thing. It just makes things a bit interesting. I don't care if a guest wants to use the term bathroom... or kitchen. I use the nautical term and they may pick up on it or not. It amounts to a hill of beans.
#34 ·
Spinnakers are not the answer in a occasions. As the wind pipes up and the distances increase Goosewinging is fantastic.
In a lot of the long tropical passages, trains-Atlantic and trains-pacific is the wind is too far behind, and a hell of a lot stronger than the pilot charts.
I've had weeks at Goosewinging main deep double reefed, and just a sniff of genoa unrolled, polled, in 25 to 30 and a squall every hour or 2 to 40-45.
All I need to do is roll a bit more genoa and hang on.
People do try to hold spinnakers for long passages but they invariably pop in some squall.
As for Catamarans... They need to gybe down wind as the really do slow down when the wind is behind 150 apparent. They work hard and lose time each gybe. But the strapped down mono at close the hull speed is doing 30 degrees better course. Game on!
Mark
