I have an old Evinrude 6 HP outboard engine on my sailboat. Is there a way to rig this to the battery to charge the battery as it's running, or do I need a more recent engine with an output for this?
As far as I'm concerned yours is the right aproach to the question.I have a 8hp Tohatsu OB on my boat, when running above idle speed it will output around 13.5-14 volts, but only a few amps. I replaced nearly every light in the boat this spring with LED bulbs because the draw from the old nav lights, steaming light, and chart plotter/sounder was more than the output of the engine.
Now with all the nav lights replaced, and the cabin lights replaced with LEDs, I can actually put a small charge into the battery when running the engine at night.
I'm going to replace the steaming and anchor lights sometime soon as well. two nights on anchor coupled with the chartplotter being on (for the anchor drag alarm) combined with daytime use of the instruments pretty much killed my 2 batteries attached in parallel.
