With some time off work I've been catching up on my Practical Sailor reading. This months' issue (Dec 2019) has a report on fuel filters. No author is listed, but I suspect that @pdqaltair either wrote it or was closely involved in the testing.
I replace my Racor spin-on primary filter once a year, and last did it in late September 2019 (as described here). I had used about 35 gallons of fuel since the prior filter change (in August 2018). After changing it (a very messy job), I eliminated the last traces of air by operating the hand pump on the Racor housing a few dozen times. After doing that I was startled to see some crud which had apparently been hiding up around the rubber pump seals (or the brass hose barb fittings?) fall down into the perfectly clean bowl. I then reluctantly took the whole thing apart (another messy job) to capture the stuff that had fallen into the bowl. This is what it looked like:
I had been thinking all along that this apparent "petri dish cocktail" had to be bacteria, but was puzzled that I have never seen any sign of water in my fuel at all. After reading the PS article, I realized that it's possible that these particles are not biological, but instead are polymerized gunk from stale fuel (asphaltenes), which could be just what I had hiding out in the pump mechanism. The article mentions a good way to determine whether filtrate is biological or asphaltenes - just splash some bleach on it, and bacterial material will turn white while asaphaltene will be unaffected. I had disposed of my filter last September, but I retained the sludge from the Racor bowl, so I pulled out a hunk of that on a paper towel and splashed it with bleach. Here is what I found:
Before bleaching:
After bleaching:
Based on the absolute lack of change, it looks like it's not bacterial at all, which makes sense since I've not had any detectable water in the tank. I do realize that this does not prove an absense of bacteria, since it's possible that I have both bacteria and asphaltenes. But it's this brown stuff that has been the predominant material that clogs my Racor primary filter if I don't change it every 12 months.
Comments?
In another thread I mentioned that I have followed a practice of topping off my tank at layup to prevent breathing and condensation of the tank. Unfortunately this means the fuel is 6 months old by the time I launch, and a year old by the end of sailing season. (Plus, previous owner had left the boat unused for 1.5 years when I purchased it in 2016, and there was fuel in there the whole time.) This year the tank is nearly empty, and I plan to pump the remaining fuel out and inspect it, then fill about halfway with fresh fuel. Unless I discover that leaving the tank near-empty over the winter causes serious condensation, I will no longer top off, instead keeping a smaller quantity of fresher fuel in my tank. Comments?
Before bleaching:
After bleaching:
Comments?
