Hello Sailors!
Any suggestions or help on the steps to take when properly starting or airing fuel lines on a Yanmar 2GM20F diesel engine? I am the latest owner of a 1979 Hunter Cherubini with a Yanmar 2GM20F and the PO owner had not started it since the fuel tank had to be removed and repaired for a leak. The tank is back in place and she was told that all that was needed is to replace the tank with new diesel fuel, air bleed the system and that the engine should start? However, I am not sure it may be that simple or can it be? When I have asked her several times when was the actual last time the engine was started she says she can't remember? Your tips and suggestions would be greatly appreciated! Doing this work on my own!
Cheers,
Annie
Cheers,
Annie
